danielmid
Southeast WI
2015 Sport 4x4
Just picked up the Ram.
Ended up not only installing Fox shocks all the way around, Maxtrac front springs (completing the 7” lift), and oil change, but also upgrading all 4 brakes (Rotors and pads).
Now…. Top Romen for a while :Big Laugh:
The Ram, and the Land Yacht
a little difference in height between the two,
New rotors with the Fox’s peeking out
rear view
fronts
Next up on the wish list…….
1, Air lift for rear when towing
2. Onboard air for above,
3. I’m thinking Red Core 4x4 arms.
:waytogo::waytogo::waytogo:
I think the Fox IFP shocks generally need the body up towards the frame and shaft down to the axle, i would probably flip them over. But I've found conflicting info so I can't quote any Fox docs on this.
Socalramfan
Huntington Beach
2011 Big Horn
hmmm, had not run into that as well. Any supporting documentation on that?
G-Ride990
Administrator
Administrator
Chandler, AZ
Side note gents, totm is about to go away... We need some more members jumping in there so toss some pics up!
Dinky
Oregon
Only drove home about 2 miles, so can’t give an honest evaluation.
I do like the stance with the extra few inches made.
I had no complaints with the others (KYB) front, Max Trac standards for rears, but seeing as how I had to change out the front shocks due to the taller springs….. I decided to just do all 4 together.
7-8hp more over bumps lmao. They were night and day different than stock. If the springs the shocks will really show.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
rear view
fronts
Yes your rear shocks are indeed mounted upside down.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
This is correct “most” are installed body up. The give away on his are the sticker the Fox name is upside down. It’s stated in the last paragraph of the documentation provided with that model shock.
Fediej
Wisconsin
EcoDiesel
rear view
fronts
The stance you have works well with the mini fender flares. I love the Mopar stripes too. Check the orientation of your rear shocks though, looks like "FOX" is upside down...
Socalramfan
Huntington Beach
2011 Big Horn
Until you mentioned it, I hadn’t even thought to look. Fox is closed today, so I’ll have a call into them Monday morning and see what they recommend for my application.
I too could not find anything definitively one way or the other.
Either way, thank you for pointing that possibly :waytogo:
Socalramfan
Huntington Beach
2011 Big Horn
Thanks. Fender flares are actually 2500’s. I’d rather have a little tire poke, than looking like bat wings. Tires are 35’ 12.5, so I’m happy with that :waytogo:
Stripes will be filled in with matte black, for a ‘ghost stripe’ effect. Played around with the striping to see if I liked it or not…… which I do, that’ll come on another weekend :waytogo:
smoothee
St. John's, NL
Installed new pan and converter. Been gone a lot for work so trying to do it piece by piece so when it comes time the actual swap "shouldn't" be too bad
670hoth
Maine, USA
Added gloss black door handle and tailgate handle covers, added red vinyl inserts on grill and tailgate RAM emblems, installed new rear brake pads and red Dorman caliper covers on my blackout 2017 express.
Socalramfan
Huntington Beach
2011 Big Horn
Pics….pics….. let’s see some pics :waytogo:
ram1500rsm
Trabuco Canyon, CA
Some shocks can be mounted either way, in this case body size down and I believe those Fox With IFPs fall in this category. When in doubt contact the manufacturer. They look better body side up in our application. . Do you know if they came with offset spacers for the top mounts ? If you look on videos I think every single rear shock install for the RAM 1500 has the rear shocks with body up. Icon 2.0 instructions call for body Up. King and Fox 2.5 instructions call for body up. Don't know about the instructions for the Fox 2.0 but should be up for the RAM application. Contact Maxtrac they should have specific instructions for their lift.
Socalramfan
Huntington Beach
2011 Big Horn
I agree, both are local companies, I’ll be calling Fox in the morning.
Appreciate the response :waytogo:
