regcabsplz
so I’ve been considering a 2” or 1.5” puck type leveling kit for my 2WD 1994 ram. now I know the truck will handle different, but I don’t want it to handle bad or the steering to be loose. I’m almost done with my ball joints and tie rods so while the front end is apart now would be a good time to get this done, but I want to get it done right. If I need to purchase better shocks, drop type pitman arm/idler arm, longer sway bar links, or should I go with taller springs?
I’d appreciate any feedback or suggestions on what I should do or what you did on your set up.
Thanks in advance.
Thanks in advance.
