Jaxfl
2019 Ram Hemi engine light is on dealership says no codes?? What now?
I was thinking the same thing as this guy. Any mid level or higher scan tool should be able to tell you if the CEL is being commanded on and for how many miles/ warmup cycles its been on. that should point you to weather or not it may by a PCM issue.Is the CEL on with the vehicle running or just key on? The only time I came across a CEL with engine running but no codes it was a faulty PCM sending a request to turn on the CEL.
