Squeal from the radio?
FL-RAM
PENSACOLA, FL
2022 Bighorn Night Edition
V8
Yesterday the radio started squealing. At first i thought it was an air leak from the engine or window. Really high pitched squeeeeeeeeek for about a second or two, then it would go away, then squeak again about 5 seconds later. I turned off the headunit and it stopped. It eventually went away. That was weird. Anyone else ever have this?
14 Lonestar
Are you sure it was a squeal and not a beep, the Uconnect 5 system has a speed alert system. Check your settings and see if it is activated.
FL-RAM
FL-RAM
PENSACOLA, FL
V8
It was definitely a squeal. Wasn't even moving. Was in a parking lot.
14 Lonestar
Ok, very strange. Did it come directly from the radio or through the speakers?
FL-RAM
FL-RAM
PENSACOLA, FL
V8
The headunit. I turned the speakers down and it still made the noise. It stopped when I turned the unit off.
14 Lonestar
Keep an eye on it and if it happens again possibly record the sound for the dealer.
KevinB1974
Pittsburgh, PA
2021 1500 Laramie
5.7 V8 Hemi
Mine makes a squeal after shutting the truck completely off. If I sit there, there is a 5-10 second squeal that I do not know where it is coming from, but the truck and all the accessories are off?
FL-RAM
FL-RAM
PENSACOLA, FL
V8
To be perfectly honest, I'm an idiot. After extensive troubleshooting I was able to determine that the source of the squeal was the squeezy water bottle I had in my dash cup holder. Basically it was air escaping.
Bigs
Gatineau, QC
5.7L HEMI
Sounds like something I would also do! Actually sitting at work and my coffee mug was doing that and thought it was my laptop. :D
FL-RAM
FL-RAM
PENSACOLA, FL
V8
Many years ago I bought a used BMW. It started making this weird buzzing noise. Could not for the life of me figure out where it was coming from. Eventually took it to the shop. A couple hours later they called and said they discovered the issue....the previous owner left a pager in the glovebox.
