I’m looking for a source of a new third brake light. Everything I find available online is all LED Euro looking stuff. If you’ve followed my truck at all, you’ll know that is definitely not my thing. I want a factory piece or as close as possible to it. I only want parts on my truck that look true to the time period it was made.
I’ve already done some restoration work on my original light about 2 or 3 years ago just to make it more presentable and try to preserve it a bit longer. I wet sanded the rough oxidized surface of the plastic and sprayed it with clear coat, so it is at least shiny. Unfortunately, it is still discolored and has cracking beneath the surface. I’d sure like to replace it with something fresher looking. Has anyone found a source for these? Or something from another similarly aged truck that will retrofit to it?
