2014 5.7 gas cap light
Dylankeller94
Vancouver Canada
I just recently picked up a 2014 1500, it has 160,000kms on it and I just got back from a 1,300km road trip. On my way back home the gas cap light came on and it will not go alway. I have made sure the gas cap is closed properly but it is still there. No check engine light or anything, as soon as I start the truck the little message pops up saying gas cap open or whatever it says. I don’t seem to be losing any fuel mileage, I’m getting about 700kms a tank highway. Any ideas where to start looking?
Socalramfan
Huntington Beach
2011 Big Horn
The warning can be reset. If it happens again….. time for next cap.
Socalramfan
Huntington Beach
2011 Big Horn
My understanding is with a scan tool. Had my mechanic reset mine quite some time ago.
Not sure if battery disconnect would work…… but hey, why not try :waytogo:
Ghost1500
Massachusetts
5.7L
So, did it go away? Your leaving us hanging. lol..... Just kidding.
Best regards,
-Mike
Dylankeller94
Dylankeller94
Vancouver Canada
Best regards,
-Mike
It came back I can hear a ticking coming from the tank while the truck is running so I’m guessing somewhere under there the Evap system is leaking some air. I just haven’t had time to go find it yet
Forget the cap for now ...............
It is very seldom the problem, just like a split hose seldom splits for maybe 12 years
I would almost bet that it is one of two things
EVAP PURGE SOLENOID
Video:
or this part, back by the charcoal canister
Dylankeller94
Dylankeller94
Vancouver Canada
EVAP PURGE SOLENOID
Video:
I replaced the charcoal canister and the purge solenoid AND the detection pump.
Dr. Righteous
Jamestown TN
Same issue with my '14 RAM.
Got the gas cap light. Meh, figure it is 8 years old probably worn out. Replace it same issue except now I've got he major evap leak code. Replace the sensor/valve assy on the gas tank. Clear the codes, week later throws code again. Only thing left is the purge valve assy under the hood. Replaced it last week. I still have the gas cap light but no MIL light or code. IF it does it again I've got a leak in the evap system somewhere, likely a fractured plastic line.
Another thing. I was smelling gas fumes but after replacing the valve/sensor assy on the tank, that stopped but was still getting a code.
Ganoze
Philadelphia
So where else in the system is the leak located. The vacuum hose to the purge valve solenoid back the the fuel tank?
Dylankeller94
Dylankeller94
Vancouver Canada
i ended up finding the issue. I fully dropped the tank, built a homemade smoke machine and ran it through the tank. The little plastic piece that is moulded into the tank that vents had 4 holes all around it, plus the EVAP canister had a broken line on it. Unfortunately you can’t replace the moulded plastic piece without buying a new tank, so I plastic JB welded the hell out of it and replaced the line and it has been fixed ever since!
mmcquinn
