Chrome LED Tail light
oldroy61
Celina, OH
6.7 Turbo Diesel
Yeah I bought some Chrome LED tail lights off of Laramie and I tried to put them on my (thought it was plug and play) 2018 Tradesman , well that didn't work.
Does anyone know of a conversion wiring harness for this problem, or a work around or something else. TIA
OC455
Central NY
I believe there is an adapter harness for the OEM LED conversion.
Here:
Brian2081
Weatland Michigan
When I swapped out my factory tail lights for factory led tail lights, I went to the scrap yard and removed the led plug and 6 inches of wire harness from the truck and cut and soldered and re pinned connector to match my wire harness.
Went into BCM and changed all lights to LED configuration and have had no problems for over a year and a half.
The only thing I have not done is run the wire to the BCM that tells it the light is not working. Big whoop.
O
oldroy61
Celina, OH
6.7 Turbo Diesel
OC455 thats just what I asked for, thanks thats great.
Brian2081, my junkyard aren't that nice , all they want to sell
the whole wiring harness. But i"m still lookin' for the ends.
Also trying to get them from the guy that I bought them from.
Thanks again!
jr27236
New York
Thanks again!
I'm looking for replacement LED lights for my 16 limited which has a couple of burned out leds in the OEM assembly causing the dash to indicate a "right tail light out" error. I personally would just stay with your reg $3 bulb ones and avoid all future trouble with these.
O
oldroy61
Celina, OH
6.7 Turbo Diesel
Well guys I'm still looking for tail light pigtails, albeit not to hard. So if anyone
has some for stock LEDs from a Laramie, I need them. Thanks
reddawg67
Winder ,Ga
I purchased a set of factory adapters from @wayned87 to fit the lights then a set of retroshop resistors .fyi for what I got ******* in this mod I could have got the complete set of last fit led light kit .You will need to change the setting in alpha if you have the halogen factory lights
O
oldroy61
Celina, OH
6.7 Turbo Diesel
Thanks for quick reply reddawg67, I emailed wayned87 to see if he had pigtail or
connector. Correct me if I'm wrong, I didn't think I needed resistors if I changed it
the setting with Alpha OBD?
