Front diff 4WD Actuator
Richard Kim
Houston, Texas
Drove my son to San Luis Pass (Galveston, TX) for a fun night of gigging. Tried to engage 4WD and the 4WD service light lit up. My son who was standing outside the truck said it sounded like crap. Sure enough a terrible grinding noise was coming from the passenger side. Got home and sure enough the plastic housing for the electronic was cracked near the metal housing. Has this happened to anyone else? No sign of something hitting the plastic housing as I rarely off road where a rock could reach the assembly. Any ways ordered OEM (68216944AA) and will install soon as it arrives. Will post pics of the damaged part when I change it out.
crazy jerry
WY
if something hit it there will be obvious impact damage. the plastic main body is fairly thick. surely it cant just crack for no reason
R
Richard Kim
Houston, Texas
Jerry,
I looked at it closely and it looks like the motor torqued the housing and cracked it. The new part is on the way; will take pictures of the broken unit to get a better idea of what exactly happened. Glad it happened now vs. in the middle of nowhere Big Bend National Park!
crazy jerry
WY
ive not taken one apart but theres a spring in there i believe to prevent over torq
Gr8bawana
6.7 CTD
Jerry,
I seriously doubt that just the act of trying to engage 4wd would crack the housing. That would mean every truck out there would break the housing when engaging 4wd because of the motor over torqueing? :rolleyes:
22hemi13
Tucson AZ
2014 2500 4x4
Something got lucky and smacked it. I’ve wheeled my truck hard for the last 4 years and never had an issue or even broke it on a rock. I’m very aware it’s there but it’s pretty solid. I’ve seen one truck I was wheeling with have it go bad after a creek crossing. But I think it was cracked already too. That truck was the poly performance ram and it was a quick easy fix. I wouldn’t worry to much fix and forget about it.
R
Richard Kim
Houston, Texas
Pictures as promised. Surprised at the plastic gears and brushed motor.
R
Richard Kim
Houston, Texas
It was an easy fix. Got the OEM part for $400 and it took 10 minutes (4 10mm bolts and a connector).
crazy jerry
WY
oe part is only 125 at cm gearworks. did you take apart the piece that has the fork ? wondering if theres a spring on both sides. is that a hole at the red arrow ?
