Tail light comparable with OEM LED setup
jr27236
New York
So I searched to forum to no avail. My 16 limited with factory LED tail lights. Dreaded 3 bulb burn out causing MIL message. Is there a way in ALPHA to turn this message off or what tail light are plug and play with the LED package? Can't seam to find if anyone has just purchased a set and replaced and go?
Kalill Nieto
Fort Lauderdale
With any aftermarket model you will have to do some wiring mod and add resistors if the set wont come with them. And you may need to deactivate and activate some settings with alfaobd.
Xsen
Urals, Russia
So it seems you can just add the relay and live on with the semi-failed stock LED taillights, without any warnings from the BCM, or am I missing something here?
Not that it's a great solution by any means, but looks technically possible.
jessie_m
I swapped factory led on my '16 Rebel to Vipmotoz sinister oled neon tube a year ago. Plug and play excluding a simple wiring harness shuffle on the lights, no error messages and a very good looking alternative to factory.
