The "quiet miles" for my 6.4 on RL 0W40 were much shorter than RL 5W40 before tick returned. Sadly, I didn't try 5W30.
I was wrong on the patent, to much information i got some mixed up. He worked with shell on the development of star polymer VIICan't recall who @ BITOG mentioned star polymer vii, neither do I recall any mention of proprietary to a patent. Perhaps HPL sells it? Amsoil and Castrol 0W-40 didn't shear much either on the Blackstone report from BITOG.
You know one of the issues with the GM lifter issues was the oil galley in the lifter's would get plugged as they were too small in some batches and that would cause the lifters to get stuck due to oil not getting through the passage.Seems strange - forum owner data reports lifter tick related to oil additives and flow, not viscosity. Except for cold ambient flow reduction on startup, of course.
Why would sheardown of high additive oil cause ticking? i.e - 0W-40 shears to 0W-30 or 5W-30...so what?
Are the sheared molecules oxidizing and creating deposits that restrict oil flow in the engine? Seriously wondering.
Lubrizol calls them "asteric" modifiers:Can't recall who @ BITOG mentioned star polymer vii, neither do I recall any mention of proprietary to a patent. Perhaps HPL sells it? Amsoil and Castrol 0W-40 didn't shear much either on the Blackstone report from BITOG.
CCS/MRV are the most relevant indicators of cold temp behavior. Keep in mind that their Super Car oils are essentially a "full SAPS Euro" additive system; I believe it is VW 502.00 chemistry. So, very different than the API SP style chemistry that their other oils are using.All I did was shade in green a statistically better performance data between the two brands. If I shaded both, it means they were near equal. If I could attach the excel spreadsheet instead of a screen photo into the forum, you could see it much better. But it's not capable of it.
The thing you can see with HPL Performance Plus and Super Car is the use of API Group IV PAO base oil stock instead of Group III, pushing the CCS & pour point capability down to colder temperatures. But it made no difference in shear resistance (HTHS).
I guess HPL doesn't seem to be anything special compared to Red Line - EXCEPT with Red Line 0W High Performance Series going away, being replaced by some consumer API SP recipe. In that case, the HPL would be an acceptable substitute.
If you say so. Did you miss my earlier post on why I think their 5W20 still has VII?5w20, no vii's, that 0w40 has plenty.
either way, it certainly has less vii. But that was a redline post and dave from redline says it doesnt have vii.CCS/MRV are the most relevant indicators of cold temp behavior. Keep in mind that their Super Car oils are essentially a "full SAPS Euro" additive system; I believe it is VW 502.00 chemistry. So, very different than the API SP style chemistry that their other oils are using.
to be 100%, I just don't remember, I posted his email, that is all I got. I think we were chapped because the viscosity was lower, I still think it has potential either way based on what the email said. Like everything else, ram forum will decide when ram forum runs it.@Burla - didn't you say once Dave @ Red Line talked about reducing moly for their upcoming 0W API SP formulation? Or was that only zinc? Zinc was always meant for solid tappets anyway. Hence the high zinc race formulas, along with high temp capability of polyol ester base oil blend.
I know API SP requires rebalancing oil additives to a more expensive detergent/dispersant additive (less calcium, more magnesium) to eliminate LSPI, which shouldn't really matter to any of us with Hemi's. It's the anti-wear additives that are critical to our Hemi drama queens, esp. moly for some reason. Perhaps because it acts more like a dry film lubricant than Zinc dialkyldithiophosphate, which eats steel at a slow, sacrificial rate (a mild EP additive, if you will).
Either way, a 5W20 that is PAO based will probably have a minimal quantity of VII, if any. So in the grand scheme of things, it is really a mute point.I have emailed dave hardly at all, I will ask him again of redline and vii's. Sadly, lately is less forthcoming with formula, but I can try.
