KahneFan
Here's a "mod" I've wanted to do for 40 years now. I used a relay to make it power off when my truck is on and it powers on when my truck is off. I don't drive with the flashing red light.
LED: https://tinyurl.com/amazonledstrip
Helpful video to understand the relay: https://youtu.be/zGlWCBoQSyo
Relay: https://tinyurl.com/amazonrelay
You'll need to use 87a to make it power up when the truck powers down. 30: constant power. 85: ground. 86: to a power source that powers up with the truck. 87a: LED strip. 87: not needed, unless you want something to power up with the truck. Also, I had a spare inline fuse laying around that I put between 30 and the relay. That way, if something goes wonky, the fuse will pop first.
2019 Ram 1500 - iJDMTOY 20 inches 48-LED RGB LED Knight Rider Scanner Light
I used a relay to have this turn off when my truck turns on and it turns on when my truck turns off (as is shown in the video). I am not driving around with ...
youtu.be
