Sun visor
hopalong1949
San Antonio,TX
my Sun visor on passenger side came out of the roof. Anyone know how to make t stay in? It’s a 2020 ram 1500
SixAddict
Phoenix, AZ.
2019 Ram 1500 Laramie
This happened on my drivers side, found that I could just “knock”/“smack” back in place, from the bottom bend. It kind of snaps back into its spot.
Considered taking it in to stealership but then did the above.
SixAddict
Phoenix, AZ.
To update, my visor is still broke. The method of trying to fix it, as noted in above post just delayed the inevitable.
I have an appointment Tuesday at stealership to see if it’s still covered, and if they have the parts. Looks to be held in place by plastic sleeve that broke. Seems like to much weight (visor) hanging from that little plastic piece to me.
SixAddict
Phoenix, AZ.
Went to the stealership today, I have 4 months or 5k. miles left on warranty so everything was covered, the fix was replacement of entire sun visor.
crshinn74
Colorado
5.7L
Same thing just happened to me. My dealer wanted $340 to fix it. Did you find a solution?
SixAddict
Phoenix, AZ.
Yes, mine was covered under warranty. Replaced the entire drivers side visor. Yours might be under warranty still. I was told the 3 year 36,000 mile factory warranty covers trim pieces but not the extended warranty….? Strange.
Also welcome to the forum.
crshinn74
Colorado
5.7L
I'm just outside the warranty at 41k miles so it's not covered. Same story with the extended warranty, trim pieces aren't covered. My head gasket also needs to be replaced already and of course it's back ordered. Seems a bit early for this many problems on a 2.5 year old truck.
Thanks for the welcome.
SixAddict
Phoenix, AZ.
Sorry to hear this. Wow head gasket gone already, not good.
Hope you get it sorted out.
