I may have missed it but, what did your failed cam and lifters look like? Was a lobe missing? If so, how long was it driven with the tick?
Unfortunately, fixing your problem is going to take more than a few hours but well worth it to do it right. Since you've already test-driven it, I would pull the valve covers and do a leak-down test. This would be my first step because you can't do it after pulling the heads and it's a PIA checking for bent valves after the heads are off. This would indicate a bent valve or push rod (the result of bad timing). If you're semi-lucky in this step, you find a bent push rod and know it's because of bad timing.
2nd would be to pull the timing cover off to verify timing. You can use a small surgical (flexible head) mirror to get a peak in there or the video camera on a phone to see the mark (record a video since your head can't get in there). If the timing is good go to step 3.
3rd is to pull the heads and ensure that the lifters were installed in the correct bores (the directions can be very confusing at times). If you're on step 3 and find that you installed them incorrectly, you're lucky. Just relocate them to the correct bores.
Hopefully, you find the culprit before step 4 because now you've likely got a catastrophic problem in your engine.
4th is to verify your lifters are good, which they probably are since you said it sounds like a sewing machine and they seldom fail. BTW: I've performed these steps about 4-6 times over the past 9 months. Hope I haven't missed a step.
