ramffml
- Joined
- Jul 12, 2019
- Posts
- 2,811
- Reaction score
- 5,142
- Location
- ramforum
- Ram Year
- 2019
- Engine
- hemi 5.7
The actual ratio changes a bit below 6th gear between the two rear gear ratios.
What you state is true for 6th gear and up only.
There is a similar thing going on for most of the gears, though 6th and 7th is definitely the closest match. But you're missing the point. If 3.21 is in 4th and 3.92 is in 6th, whose truck is putting more power down?
Essentially when it comes to the specific choice between 3.21 and 3.92, you gain a lower gear and lose an overdrive with the rest being so close it's not even worth worrying about.
