3000 Grit Mistake
DaveNC
US NC
soo, I'm a dumbarse. my 19 Rebel had some light scratches from something climbing up or down my C pillar. Also some smaller ones by gas fill door and drivers door. Wet sanded the C pillar, followed up with polishing compound, meguiar wax and sealed with Avalon King. Looked good so I did the same for the other 2 areas. didn't do as good of a job and figured they must be deep. Cut my loses and did the same to remove the haze, polishing compound, wax and sealed it. Looked good. Went out one sunny day and with the sun at the right angle, boom, haze where I tried to fix the deeper scratches. now what? I don't have a DA just elbow grease. Anyone recommend something to remove the haze, knowing i have to cut through the ceramic coating (only 1 layer)? Last resort is to take it to a detailer.
Treburkulosis
Your High End Detailer
Haslet, TX
Post some pictures.
2015OneTon
Minnesota
It's going to be tough getting rid of the haze with elbow grease.
Personally, I'd buy an inexpensive DA polisher before I brought it to a detailer. This way you have a polisher for future use.
D
DaveNC
US NC
Here is the best i can get. Excuse the dirt running down from the window. she needs a bath. IMG-0538.jpg
quickster2
SE Michigan
2015 Ram Laramie 2500 4 X 4
6.4L
You may want to take it to a detailer or a local body shop to get an opinion. It might save you money in the short term not having to buy tools, polish, etc. Hard to say how deep the scratches are from the pic. You could invest in in a YiFeng Clip on 60X microscope for your smart phone or a Carson 60 to 75X Micromax LED microscope for a small investment to tell how deep the scratches are before attacking them. Both of the products mentioned are available on line. If not these brands then something similar. Good luck.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Here is the best i can get. Excuse the dirt running down from the window. she needs a bath. View attachment 485361
Post a picture as close as you can get it ... from that distance it looks like a very bad hologram ... try to get some like inches away and from both angles and then directly in front please ...
OC455
Central NY
yogibear18
Finish rubbing it out with a bit more aggressive rubbing compound then finish it off with wax, get yourself a DA Polisher to do it with
