colianci
I was looking a this 8.4 inch screen I bought but the bezel and hvac blower speed conversion kit was too expensive so I thought of putting the old 5 inch screen bezel with the radio out its almost the same size just a bit more round so I tested it and guess what it fits to see look at the pictures and the climate fan which air vent to shoot out of it all works just no volume control but there is blank spots too make a hole into to fit on in like look the 4 speed bezel with volume control it shows you every you need to do to make it work but it's also 300$ and I can't find it used plus using what you already have is nothing to complain about it just seem like a perfect way to get past the expensive bezel and expensive 4 speed to 7 speed conversion kit but if someone can help me because I don't have the technical knowledge and skills to do it my self I can plug a adapter harness and fit a volume knob into plastic via drilling a hole but other than that I am just a man with a idea if some can help that would be very nice
