Replacing the rear pinion seal (Help needed)
ghost_leader07
USA
Hello,
I'm in the process of replacing the rear pinion seal on my 2006 Dodge RAM 1500 5.7L, i have already took off the old pinon seal and the new one is ready to install but i don't know what's the best way to press the seal onto the diff, i don't have a seal installer tool or a big enough socket that would go over the seal, i'm not comfortable with hammering it, any ideas on how to install it?
Your help is greatly appreciated.
Greylord
Canada
5.7 l
Try a large socket (just big enough for the outside edge of the circumference. Or a soft punch/ wooden rod and a hammer. lightly work your way around. Don't forget to add grease to the garder spring before hand.
Rlaf75
East Hartford CT
I've tapped them in with a hammer several times and never had an issue
