I Have a 2021 Laramie 5.7l e-torque with stock exhaust. I have been doing research on the site and the internet trying to figure out the best exhaust. I would like a true dual set up, at the moment it ill be cat back. The plan is to cut the pipe where the join and run separate mufflers and tips.
I am looking for opinions to see what you recommend for mufflers/exhaust set up. Do not want a lot of drone in the cab while cruising.
I called a shop and they wanted to make sure that changing my exhaust wouldn't void the warranty. Past research is that the dealer has to prove the exhaust caused the issue. Not sure if that is true. if anybody has any information regarding that please pass it on.
Thanks
Thanks
