Riccochet
- Joined
- Aug 14, 2013
- Posts
- 1,796
- Reaction score
- 1,618
- Location
- Somewhere around Charlotte
- Ram Year
- 2020 2500 Laramie Longhorn
- Engine
- 6.4
Started with an EAZ-LIFT with 800 lb bars, went to 1000 lb bars and dual friction anti-sway bars. Just trash. Went to a Equalizer 4P which helped a lot, but still kinda sucked. Bought a used ProPride. And while it towed ok, it was freakin heavy. You're adding 200 lbs of tongue/payload.Riccochet curious what weight distribution hitch were you using towing your TT with that 1500?
I don't even need a WDH to tow with my 2500 if I'm only going 30-60 minutes away. Couple inches of sag and it tows straight. If I know it's going to be really windy or I'm going long distance I use the Andersen WDH. Light weight, easy to connect and disconnect, quiet. Does really well.
