18 Longhorn
I bought a light bar recently and aside from the 2 wired connector it has it also has 4 other wires hanging out aside from the connector what are those for does anyone have an idea?
Maybe post a picture or a link to what lightbar it isI bought a light bar recently and aside from the 2 wired connector it has it also has 4 other wires hanging out aside from the connector what are those for does anyone have an idea?
This is what was in the box I will try to get a picture of the connection in a moment it is from avw off-road and performance.Maybe post a picture or a link to what lightbar it is
It has rgb function. The 4 wire should be for rgb control.This is what was in the box I will try to get a picture of the connection in a moment it is from avw off-road and performance.
You can use thisThat is what I figured but I hadn’t ordered it with that function. How would I go about connecting that? The wiring harness doesn’t have a spot for those wires so is something else needed?
Awesome thanks for the link.
