Are the current shocks worn, leaky, bouncy? I mean, my 2012 still has the original shocks on them (172k mi), and they're good. Granted it's mostly a highway cruiser.
If you like the current ride (or the ride it had before), OEM Mopar shocks would be a safe bet. They're engineered to match the spring rates of your truck (and mfgrs spend a lot of time on shocks/spring rates. They'll cost more than the Monroe/Gabriel options, but you won't have to buy 3x Monroe's for each Mopar shock either, LOL. There should be a sticker with a barcode and part number on each of your truck's shocks so you can match up exactly what you have. One more set of OEM's may be the last shocks your truck will need. RockAuto has probably the best prices on them.
Be careful if you buy aftermarket shocks with aftermarket springs ...what grade and how good are they. This is often overlooked. There was a youtube video where they tested a bunch of aftermarket springs (that came on replacement struts). Most, the wire thickness was 'off' and spring rates tested vastly different than the OEM springs. That could leave your truck bouncy or different driving dynamics. Once they're installed, then yer kind of up a creek. I would personally re-use your springs unless you're looking to stiffen it up.
Otherwise there are any number of other aftermarket options out there. I don't recommend Monroe/Gabriels, I've had too many leaks and shocks go bad in short order. If you want to go with something a schootch stiffer, Bilsteins would be a good choice.
