- Joined
- Sep 11, 2022
- Posts
- 9
- Reaction score
- 5
- Location
- Missouri city, TX
- Ram Year
- 2022
- Engine
- 6.7 cummins
Installed two JL Audio VXI-5000 amps with the VXI hub. Sounds incredible. Unfortunately, now my TPMS does not connect (just dashes) and while I can unlock/lock the doors and remote start, I am getting the "key fob has left the vehicle" msg when driving and the car honks 3 times if you open the doors and shut them while started.
My stereo shop, (by the way they are awesome), has tried several times to isolate the issue. They finally determined that one of the amps seems to be interfering with the RF Module. The amps are about a year apart in age (one is new), and the older one is the one that seems to be the issue, as evidenced by isolating the amps. They switched the amp locations and the problem persisted.
The questions: Anyone else run into this issue? Any suggestions for maybe shielding between the amp and the module? Has anyone heard of inferior chips being used in the new Ram modules?
I appreciate your feedback!
