Well, got the overhead console in. Of course when I was connecting to one of the wires on the back passenger seat pillar I dropped a screw so ended up having to take the rear seat out to take off all the trim to get the screw out so a note to everybody doing this put some tape rolled up in the bottom of the hole where the screw is up at the top of the trim on both seat pillars otherwise it'll drop down in. Also suggest using a magnetized screwdriver for it. Also, on my 2018 2500 tradesman, there was a big old green connector right in the middle of the opening where the console is so I had to trim out the tabs where other items I guess go. I only have the lights so was not a problem
