Is 2000 4.7 dodge durango engine compatible with the 2005 Dodge Ram 1500 4.7
G
Gage24
Pa
I already have it set up i just need to know about the computers
jws123
nj
To make it work you would need to take the timing chains and gears from your old motor install in new motor also the tone ring off of the crankshaft which to get off you gotta remove crank thats the only diffrences the block heads ect are the same.
jws123
nj
Also if all fails and you dont want to swap the parts I see your in PA i do have a 2006 4.7 for sale with 110k that would drop in no mods needed.
G
Gage24
Pa
How much
G
Gage24
Pa
Number to text
jws123
nj
I messaged you.
