mtnrider
- Joined
- Sep 25, 2014
- Posts
- 3,177
- Reaction score
- 3,434
- Location
- Georgia
- Ram Year
- 2016
- Engine
- 6.7 Cummins
EDIT: After reading back through the tread my issue with the "Blind spot alert temp unavailable" (in orange) may be caused by the fact I don't have the mirrors hooked up yet. Going to try and install tomorrow and will report back.
Still not sure about the right tail light out that I solved by turning the rear lighting DTC off (bottom of this post).
Looking for a little help. I installed the harness and tail lights this afternoon and having a couple issues.
I am getting a "Blind Spot Not available" message. Now my settings are slightly different on a 2016 so they don't match exactly what has been posted here. I do Not have the mirrors/LEDs hooked up yet could that cause the issue?
Here are my settings I have enabled....
I was also getting a right tail light out message. I enabled the disable here and it went away but not sure if it was an actual issue with something else?
My blinkers did not initially work but I enabled this and they started working. Didn't see this mentioned anywhere.
