My Friends Sometimes....
Scottly
Safety Harbor, FL
HO 6.7 Cummins
I guess those Ford blowhards forget about all the broken and bent frames on that Raptor POS...Hell, they advertise it doing things that cause failures they won't warranty.
icecoldak
AK
Tell your Ford buddy if he looks hard enough, he will probably find photos of people roasting marshmallows while their Ford burns to the ground.
At least these Ram photos are from people doing dumb stuff and not because Ram built the truck wrong.
Maybe all you ram guys should just haul marshmallows!--At least you can carry something around!!
Crazyro
SC
My understanding is that in the goosneck frame bend, more physics contributed than just the loading issue. Apparently someone pulled out in front of them or braked hard causing the driver to slam on his brakes, which shifted the entire load quickly forward causing the frame to take the hit of the huge load.
OC455
OC455
Central NY
What my friends do to make a point....LOL
OC455
OC455
Central NY
Pretty sure they stopped suddenly when they rear-ended someone. Bumper looks angled. Don't think you'd see too many of those ford's survive that either lol.
Well that changes the whole picture then...
Marshall
Sk, Canada
2014 sport
That car hauler picture, that's why Kenworth, and Mack build tandems.
Reminds me of a Ram picture of a 3/4 ton and payloader just dropped a 2 yrd of gravel in it.
A bit F***** up. City boys.
Around here , I have seen 2 big camper trailers been pulled by single axel freightliners trucks.
Dinky
Oregon
You are so right 'cuz hauling 6,000lbs of marshmallows is a lot easier on the frame than hauling 6000lbs of lead.
Actually it might be better. 6k of marshmallows would displace the weight a lot better at least....
1Popeye
