Hesitation or slight jerking at light throttle
Thorbeast
Nh
Last week my check engine light came on and the truck was driving a little funny. At light throttle around town it was sort of hesitating, weird to describe but almost felt like it would if it were sputtering. You can hear and feel it running funny. Engine light came on, went to advance auto
Gave a code for bad o2 sensor bank 1 sensor 1(P0133) . Ordered the oem replacement, light went out in the meantime, still was running the same so I replaced it when it got here. Didn't fix the issue.
If I get on the gas at all it runs completely normal and no issues.
Any thoughts? I also put a bottle of Lucas fuel injector cleaner through it but no luck.
2016 Ram 2500 6.4 Automatic
-S&B intake was cleaned 2500 miles ago
-Spark plugs changed about 10k miles ago
-Tuned by hemi fever with Diablo tuner 2yrs ago
-5 weeks ago made a trip 3hrs each way (72mph average) on the highway no issues
buckeyexx
Ohio
2016 Power Wagon
Maybe check the throttle body for build up around the inside. I know you say intake was cleaned so maybe you did it then but it could be acting up. Are you sure it’s engine related and not transmission? Just throwing out some ideas.
Thorbeast
Thorbeast
Nh
So I realized I ran into this issue before and was able to fix it. I Uninstalled the hemi fever tune with the Diablo, reinstalled it, truck runs perfectly fine. Happened to me like two years ago and fixed it the same way
