westcoasting
What s a good lube ( not Oem) for front and rear diffs and / what brands to stay away from please
Both front and rear you used that? Perfect!I used Valvoline 75-90 last weekend. It comes in a squeeze bag. Very nice and easy.
Others will say Amsoil us great as well.
My 14 calls for 75W-140 in the rear diff,the only change between 14 and 18 is the EPA/Cafe getting involved,the diffs are exactly the same.Both front and rear you used that? Perfect!
I use Valvoline for mine (though the other suggestions are great, too!)...it's easily found at Walmart and you can get four pouches of 75W90 and it'll be enough for both diffs. Also, if you have anti-slip, you won't need the Mopar additive. My next change will be W90 in the front and 140 in the rear.Both front and rear you used that? Perfect!
