Tire air pressure
Pines19
Iowa
Tire pressure on factory tires is 35 psi.
I put new tires on 22 Ram Bighorn.
285/55/20. AT 10 ply
What do you recommend for air pressure in these tires?
Sidewall says 80 psi max.
P
Pines19
Iowa
Changed the look of the truck
turkeybird56
Central Texas
Go to website of tire manufacturer and see what they recommend. Anything said would be Internet Guessnosis. But unless you were loaded to the gills, sure as heck not run 80 psi, lol.
ADDED: Watch PSI with cold weather. I cranked up the Red Beast and my tire pressure was 4 lbs low, due to monster cold, so drove to my garage and filled up to PSI I run, just saying. I do not want to run too low, since I am running Falkens, which R C rated 5 ply, I do not need 10 ply, not pushing that type of load or towing that heavy when I do tow. Just my particular set of circumstances.
P
Pines19
Iowa
Yeah I wouldn’t run max pressure. I’m running 40 psi now, but wondering what others are running with like tires.
CanuckRam1313
Ontario Canada
2023 Warlock SLT
I have BFG K02's for my summers 285/65R20 10 ply and run 39 to 40 psi and I find it to be the perfect pressure for wear and fuel economy.
Similarly, I run the same pressure in my winter 17" set up as well with Blizzak DM-V2's in use, and same thing.
I've not ever had scalloping, feathering, center wear, inner or outer wear issues on any of my tires.
I check and adjust tire pressure every couple of weeks, and I do an alignment check and adjust if needed, twice a year (when I switch from one season to another).
LouM
Greeenwich/Easton upstate NY
2015 Ram Ecodiesel crewcab old/ now 2019 Laramie Hemi
eco diesel old / now Hemi missing the eco's mileage
My 10 ply E range on my 1500 I run at 50-55 PSI in the fronts and 45 PSI in the rears.
These are my snows this will be there 3rd season and the wear is good and even across the tires.
jejb
NW Arkansas
If you put 10 plys on a 1500, just go with whatever the sticker on the door frame says. The only reason I could see going with more pressure is if you intend to overload the truck. The 10 plies will probably already ride rougher even at the recommended pressure. No sense making that any worse by over inflating them.
Farmer Fran
Earth
2020 Limited Loaded - Sold
There is a website that shows you how to set the pressure. I do not have the link on my phone but you should be able to search it
LouM
A link to a tire pressure calculator;
https://tiresize.com/pressure-calculator/
Actually you would be incorrect in that assessment.
The RAM Rebel with the E range LT tires door sticker recommends 55/45psi F/R.
The door sticker is only correct for the tires listed on that door sticker.
brian42
San Diego, CA
I always ran mine at 60+ psi but I am in the minority on that. Towing or heavy loads was 80 psi.
I prefer the stiffer sidewall and higher load capacity. Tire wear was always pretty close to even across the tread.
That was on my 3/4 ton HD truck. I'd do the same for this truck if I had E-rated.
My XL-rated tires are max 50 psi and I run them around 45 psi.
lpennock
Phoenix, AZ
5.9L & 6.7L Cummins
Toyo has a the TRA data for the common tires so go to the following link and pull the table. Just look up the load of the old tire at the placard pressure and then pull the pressure for the new tire that provides that load.
ctwalton15
Kansas
35x12.50r18 BFG k02 I typically try to run 50-52 psi in mine.
Daniel Ortiz
Cypress, TX
5.7 L Hemi V8
@Pines19 , I second the use of the TireSize.com "Calculate New Tire Pressure" calculator that @Farmer Fran and @LouM reference. It takes into account your stock tire size, stock pressure from your placard, new tire size, and payload capacity to calculate a new pressure, and it includes the 10% factor recommended when switching between P-metric to LT-metric tires. I believe it's based on the tire loading tables generated by the Tire and Rim Association, and it's by far the most comprehensive and reasonable method I know to come up with a new tire pressure for your new size tires. It's basically a calculator for the process linked to by @lpennock above.
Farmer Fran
Earth
My stock psi was 36psi. I now run Continental terrain contact in stock size. I now run 36. But still looking for optimum. According to most sites same size is same pressure.
285/45-22 size
brian42
San Diego, CA
Handy tool (and bookmarked now). I've never used that before.
As an "old guy" I always default to printed documents I can put in my map pockets:
  • Tire Load Tables_Firestone.pdf
knightjp
Dubai, United Arab Emirates
Sorry to resurrect an old thread, I just installed aggressive ATs on my truck. Size 315/70R17.
The installation shop put them at 40 psi.
I notice that after 100 kph, there are vibrations on the right side... These are side to side. I was told that perhaps the tires were over inflated. So far we've checked the balancing twice.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Psi within 10psi of the door sticker will not cause vibration. It’s a balance issue
