Kmorrisey
**NEED HELP! PLEASE SHARE AND MESSAGE ME IF YOU HAVE THIS ISSUE**
I have a 2022 ram 3500 HO with 22,000 miles. It’s been in the shop four times for a P2459 code which is a regen frequency code since 17,000 miles. Chrysler has finally decided that fuel contamination has caused the injectors to fail resulting in more soot production. They have put a restriction on my truck and want me to pay $30k (confirmed each injector is $2400) to fix it before they will lift the restriction. They pulled their sample after the filtration system and claimed they can see dirt in it. I had a lab test my fuel and determine it is good. If dirt causing the injectors to fail is true then it is a filtration issue that should be covered. I included their test procedure, pictures of the fuel, test results.
Thank you for any help, I refuse to roll over for Chrysler
