Suggestions?
MarcoFuc
Tallahassee
Going to try and explain this the best I can.
So I recently got camshaft/lifters done and upgraded the oil pump at a shop. Now I’ve noticed a tapping almost sound when the oil is 190+ and when at idle with psi at 30-34…. And driving at 68-70 psi and then I’ve noticed also sometimes when driving and I come to a complete stop at a stop sign or red light it would drop to 26 then rise to 34 with a 5-10 second delay this rarely happens.
Anyone suggest anything? Running 5w30 instead of 5w20? I use Pennzoil 5w20 full synthetic high milage..
MarcoFuc
MarcoFuc
Tallahassee
Yes run 5w30 new lifters will tick and tap for a while takes a good 2k miles for them to break in even then hot idle can be a little tick your oil pressure is normal.
I did my first oil change 2 weeks ago I’ve put on about 4500 miles on already. My next oil change I’ll do 5/30 suggest any oil filters? I use k&N
jws123
nj
Alot of ppl like the royal purple filters honestly down to prefrence i use purolator boss just never use a fram filter on anything you own every blown motor i get has one on it just saying.
Jeepwalker
WI
2012 Reg Cab, 4x4
Some people just love that orange can! :rolleyes: Coursee there are different grade products too. They're not all that 'fall-apart' seam product ..I guess.
OP, let us know after a while how things go with the sound. Yer sure it's not the exhaust manifolds, right?
MarcoFuc
MarcoFuc
Tallahassee
Yah fram ive never used, my next oil change I might try the RP filter along with the 5/30 oil.
MarcoFuc
MarcoFuc
Tallahassee
On a cold start, there is no tapping or tick, only when the engine is about 190-200 “sometimes” it’s not all the time it makes the sound. Also goes away when I rev it alittle bit
jawzs2
South Jersey
LOL - yep. Reminds me of a saying my grandfather had when someone asked him if he wanted a vegetable for dinner. He said nope, everyone I knew that's died ate vegetables.
jws123
nj
Its just something I have noticed between marine/auto engines I have rebuilt/fixed at least 50 engines most had frams ahaha.
huntergreen
Lol
huntergreen
And yet, the fram ultra is always in the top tier where ever you look at reviews.
