All Repair Parts @ Employee Cost!
AllMoparParts.com
AllMoparParts.com
- Benny
Preferred Vendor
All
All
18ram2500
Awesome Town
Hi,
Im interested in right and left bed rail caps for a 2018 ram 2500 with a 6.5 bed, no ram box.
Thanks
AllMoparParts.com
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Daw14
Hi Benny I need a few things : Two jounce bumpers part # 52855788ab. . One Oil control valve part # 53022338ab . Thanks for any help ,Vern.
AllMoparParts.com
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Hi Vern,
I will send a code you can use on these
Please let me know if you have any other questions.
Thanks,
-Benny
AllMoparParts.com
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Jwebb352
Old Town, Fl, USA
Quote for:
2003 Dodge Ram 1500 5.7 Hemi Magnum
Hardware (Bolt, spacers, dust shield) for both upper and lower idler pulleys.
AllMoparParts.com
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Quote for:
Hi,
The actual bolt for the pulley appears to be discontinued, This was part# 6507442AA
You would need to buy the pulley assembly now
Did you need the mounting bolts for the assembly as well? Here is a diagram below
Also can you give me more detail on the dust shield. Not seeing one here
- Benny
Jwebb352
Old Town, Fl, USA
I have the upper and lower independent smooth pulley setup, not the one in the picture I attached on this reply. As you see in the picture, it states this part is also discontinued, also I do have a/c.
AllMoparParts.com
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Your correct looks like it is disco but glad thats not the one you need.
The 2 smooth pulleys with hardware are the same and can be found below
Let me know about the shield?
- Benny
Jwebb352
Old Town, Fl, USA
Wasn't sure about the dust covers. But can I get a quote for the 2 bolts and does the spaces come on it? I'm confused if you couldn't tell
AllMoparParts.com
AllMoparParts.com
- Benny
Preferred Vendor
All
All
