Alpharex headlights installed in 2019 ram 1500 classic
Jpage978
North Shore Ma.
Has anyone had success installing Alpharex Pro headlights in their Classic, if so how did you do it, led drls hyperflash then do not work , about to return, which sux
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
This post may help....
Administrator
You'll probably need to either use resistors or AlfaOBD so the turns don't hyper-flash. There a few thread on the forum about changing the BCM configuration to use LEDs in the head and tail lights.
Jpage978
Jpage978
North Shore Ma.
Thanks will check out the thread
Tried resistors they didn't work
Want to go the Alphaobd route, but can't get security bypass cabled needed for 2019 Rams
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Why can’t you get the bypass harness?
blackbetty14
CT
BOD sells them
Mpgrimm2
Preferred Vendor
SC
5.7L
Kaodtech is rarely out of stock more than 1-4 days
hunterdan
SE PA
2019 classic
There are vendors on Facebook that sell them as well if you search for some of the alfaobd groups.
brianw0048
EcoDiesel
I have the AlphaRex pro series running HID low and LED high. I set everything to hid/led via alfaobd. No hyper flash, no resistors, no light out messages.
Jpage978
Jpage978
North Shore Ma.
Those are the lights that didn't work for me, I returned, but now just waiting on bypass harness so I can use alfobd, and I plan on ordering again, yeah my wife is annoyed lol
Jpage978
Jpage978
North Shore Ma.
Did you change location of drls, or use supplied drl harness?
Did you set lowbeam to hid and high to led?
brianw0048
EcoDiesel
I used the drl harness and turned off drl in Alfa. Low and high beam are set to hid I think…I used to have a diff set of aftermarket projectors and made all the changes a couple years ago.
Jpage978
Jpage978
North Shore Ma.
Thanks for the info, just got message tonight saying my bypass harness on the way, hopefully everything goes smoothly when use Alfaobd, got Obdlink mx+ like most suggested, fingers crossed
MattHemi
Nice setup! My friend is also considering Alpharex for the headlight upgrades. The new brake pads and tires from 4Wheelonline are getting installed this week and light mods will be next.
