I need some help,
After a failed install, unable to remove the black plug, I reinstalled everything including the snapring and went on a drive. I guess I don't have the snapring fully installed correctly, because the plug blew out on the highway and made a nice smoke show.
Does anyone know if there are readily available replacements for said snapring?
Edit: if anyone happens to have the same situation happen to them, or just happens to lose the snap ring when trying this job, harbor freight has a kit that has the perfect size.
Fluid was $35 at my dealer and despite it looking like I dumped all the fluid out, I only had to put in 3 quarts. (Had to pen the 4th bottle cuz my pump was too small to get the last 100ml out of every bottle)
Harbor freights fluid pump isn't the right size however AutoZone had the correct one.
Fluid cost: $35x4=$140
AutoZone fluid pump=$12
Harbor freight snap ring kit $5
Total: $157
Don't make a $160-$3000 mistake, MAKE SURE YOU PROPERLY INSTALL YOUR SNAPRING
As for the bypass valve, I have it installed (as installation was easy since the black plug ejected itself) and the highest temp I've seen in my 20 minute test ride was 140 degrees! Doing good so far, previously the temp would be up to 195 by then
Edit 2: you potentially will have an easier time pulling out that black plug if (before removing your snapring) you get the transmission warm, go for a 5 minute drive, come back and pop that snapring off and the black plug should just pop out in theory.
