Use Tow/haul - no MDSQuick question, does everybody get a tuner to shut off mds, i have a full 5 year warranty through dodge on my truck, will tuning it void warranty?
My shift strategy is unpleasant in "normal" mode. The kickdown lags speed considerably for my tastes and stays in a high gear all the way down to a stop. It won't drop out of 3rd until I'm completely stopped. If I try to get back on the accelerator to any degree the truck limps along at low RPM for a few seconds then *BAM* it kicks down and the truck accelerates.
I've had it to the dealership numerous times and every time they tell me "that's just the way these trucks are". I used to never use Tow/Haul but it takes about 1/2 of the annoyance out of it, especially in traffic when I go to accelerate and there's 2-3 seconds of lag between the pedal and the truck moving.
I've had the latest software installed and disconnect the battery every now and then to reset the transmission learning but it always comes back.
I'm not interested in a pedal controller so this is my only alternative other than just live with it.
I still put it in normal mode when cruising along but if there's any stop-and-go or commuter traffic I go to Tow/Haul so the truck is more responsive.
Why are you shutting it off ? Mine is so transparent that if it were not for the indicator on the dash I would not know it ws active.
The ECO light has nothing to do with MDS.
I’m not saying or wrong about your truck but I would have to guess something is not right if it is kicking in. I’m on my third ram with mds and I can tell you that it definitely does not activate when tow haul is in use. I could not imagine it shutting down to 4 cylinders while I am towing or hauling a heavy load. The thing about tow haul is that it locks out 6th gear or the final overdrive gear so the rpm’s alone should be high enough for it not to engage. Again I’m not saying you’re wrong about your truck but something is not right. I’m driving a 2016 now and it shuts off mds.I am surprised my gear +/- button is not worn out. Every time I jump in my truck, I select drive and click the gear selector until 8 shows on the cluster. When I forget to do it, only takes a few seconds to remember.
MDS sucks!
Tow/haul does not turn off MDS. I can push the tow/haul button while driving and still hear MDS kicking on. I have tried it many times. At least in my 2016 it doesn't turn off.
According to the article I posted (#15) that’s not necessarily true.On the 5th gen the ECO light is directly related to MDS. That's the only thing that triggers that light on the DT.
I'm not sure if it's the same on the 4th gen trucks.
From VehicleWisdom :
“It’s important to note that ECO Mode and MDS are different.
You can be in ECO Mode without switching to MDS Mode, but MDS only activates when you’re in ECO Mode.
However, most of the time, if you’re in ECO Mode, MDS is also engaged.”
What Does ECO Mode Mean In A Dodge Ram 1500? | Vehicle Wisdom
Most modern vehicles have features that reduce fuel consumption and the environmental impacts of driving. Often this setting is labeled as ECO or ecological mode. Although trucks are known for...vehiclewisdom.com
