saboken
If you go with a Tekonsha controller be careful of the connection on the unit . Mine started to act strange on my other Vehicle, what happened is the solder joints inside broke loose from removing and replacing it when not needed. Other than that it works great. I don't know about using the existing harness on Ram?
