For all those whos key gobs stop working. Worked on my 2014... Follow these steps.
Unlock doors manually.
Turn ON hazards.
Hold the lock on the fob for 5 sec.
Now put the key fob into ignition and turn to ON position.
Click unlock on the fob that's in the ignition. You should hear it unlock!!
Turn vehicle off and turn hazards off(unless you want to drain your battery.)
This works because usually while cleaning the vehicle while running, you trip a safety mechanism that disabled the fob with out you knowing.
Cheerz!!
Sent from my SM-G935T using Tapatalk
Did this procedure work for anyone? This is the only forum anywhere I found this information.
Am stuck now with a Keyfob which is not locking/unlocking. But mine is just a push start and do not need to be inserted. How can i fix this?
Why in the hell does this work!? It really does!For all those whos key gobs stop working. Worked on my 2014... Follow these steps.
Turn ON hazards.
Cheerz!!
