Headlamp mounting bolt part number help
A_mod_too_far
Colorado
Trying to identify the m6 bolt and u nut that mount the headlight assembly to the radiator support through this spacer:
I can find the bolt in the the diagrams but no one lists the part number like it was discontinued.
The u nut fell into pieces and the bolt I have is so heavily rusted the threads are gone in the middle. I did however order new spacers.
A_mod_too_far
A_mod_too_far
Colorado
Here is a pic of the u nut from the passenger side, not finding it's part number either. Found similiar u nuts that are m6 that may work though. 06510185AA
it doesnt look exactly the same but I think it may work.
the bolt is over 40mm long, trying to find one that may work even if it's not the same exact part number.
A_mod_too_far
A_mod_too_far
Colorado
The part number for the bolt is 68222835AA
Please let me know if you have any other questions.
Thanks,
-Benny
Sweet thanks. I am also looking for the u nut the attaches on the bottom side of that bolt, but it's not shown in the radiator diagram, it slides onto the headlight bracket below the spacer and the bolt goes through both. Do you know if it's available to purchase also?
AllMoparParts.com
- Benny
Preferred Vendor
All
All
I am sorry but I am not seeing a serviceable part number for that U-Nut
-Benny
A_mod_too_far
A_mod_too_far
Colorado
Vinman87
New york
Thanks,
-Benny
Hi,
I have a 2014 Ram 1500 sport vin# 1C6RR7MT6ES348236, I’m looking for the bolt and u nut for the bottom mounting hole of the headlamp. I have the spacers but i lost a bolt and u nut.
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Vinman87
New york
Hi,
I believe your looking for #8/9 from the below image but these are not serviced by mopar
I believe these are a pretty typical M10 fender bolt as you mentioned. Something like this or similar should work
- Benny
Hi Benny,
Thank you but Im looking for the u nut that secures the bolt that goes through the bottom hole of the headlamp. The bolt goes through the adjustable spacer and into this u nut. Hope my photo helps.
AllMoparParts.com
- Benny
Preferred Vendor
All
All
I see but I am sorry it does not appear to be a serviceable item. It does come with the mounting bracket but I think you can get away with buying a standard machine thread U-Nut and save some $$.
- Benny
Vinman87
New york
- Benny
Thank you for the response. Weird that you can get the adjustable spacer separate but not the u-nut.
WY-Dave
Cheyenne, WY
6.7 CTD
I believe I have the assembly from my broken headlight. I will take a pic tonight (after 2am) and see if you can use it.
