CVT's are where it's at. Ok ok, hear me out!
Infinite gears, when programmed correctly they can always give you the lowest RPM required for the job. No busy downshifting or upshifting or engine wailing unnecessarily. Towing up a hill? The engine revs just begin to climb to where they're needed, and then back off again at the top. No change in speed, no jerking gear shifts, no busy feeling. Just raw power applied as needed.
And of course you can have a fuel economy mode where the engine revs as low as possible, or a sport mode where the engine is 300 to 500+ rpms above where its needed just to give you that effortless punch.
My parents have a CVT and it's not a sports car by any means, but in a truck... if it could hold the required torque (which might be a problem), I think the "mushy automatic feeling" issue might not be as much of a problem vs guys in camaro's and mustangs who would die if it came with a cvt.
