Radio, identification, help
Rockshooter
Tonganoxie KS
I don’t know the history of the truck. don’t have any idea if the radio has been swapped out. XM , no signal, navigation maps stuck in Texas. sent radio to infotainment . that was after dealerships Said radio was bad. Need to replace. Have it back in the truck 6500AD2F-94C1-4017-89F9-DB6813439FA6.jpegthe same thing. my truck doesn’t have the pink plug-wire. could that be my problem possibly the wrong radio?
Does AM/FM work ?
Are you paying for XM radio ?
unless the GPS is not plugged in, the Nav can not know where it is
Did you take a pix of the top of the radio, while it was out ?
This may or may not be a radio for a truck like yours
Rockshooter
Rockshooter
Tonganoxie KS
Here’s a pic of my radio. just trying to figure this out. I have no pink wire. I have white olive green and purple. everything else works as it should other than the satellite radio and the navigation.
Thanks in advance RichB1A64C54-08B7-44F4-B84F-C63435552EED.jpegB1A64C54-08B7-44F4-B84F-C63435552EED.jpeg
Administrator
Goto this website: https://fcacommunity.force.com/RAM/s/equipment-listing
Enter your truck's VIN number using all capital letters, this will give you the factory build sheet (how it left the factory).
The 8.4 radios came in one of two formats, the 8.4A which did not have navigation but could be unlocked with a code. The other radio was the 8.4AN, it came with navigation and HD radio which the other version did not.
He does have 8.4 AN VP 4 North America Infotainment System, ( radio )
Navigation is stuck in Texas
that is a software issue it needs to be updated
the update site is
some times a radio is many updates behind & they have to update at one step at a time
You may want to get some advice from another member of this forum .. https://www.m2mods4ram.com/
SitKneelBend
St. Louis
3.6 Pentastar
Thanks in advance RichView attachment 517541View attachment 517541
The pink is for cellular antenna if you have the sharkfin. The mustard is GPS and SXM. It is likely that if the mustard plug is plugged in the antenna on your truck is bad (if you have no SXM and GPS). You can replace the the antenna for a GPS only one for about 10 bucks, but if you want SXM it's probably best to get a new OEM puck antenna.
18harvest
huntsville
The shark fin has two leads.the mustard and the purple.they have a jumper harness that goes from the antenna to the radio.the pink antenna if equipped is located in the dash behind the radio.i have seen a jumper cable go bad once.but more than likely like sitkneelbend said probably an antenna issiue.
Rockshooter
Rockshooter
Tonganoxie KS
I guess what I’m trying to say when I’m asking, will the radio operate and function without the pink wire. Radio has pink plug. The truck has no pink wire. Thanks in advance, Rich
chri5k
USA
Diesel
Look very carefully, preferably with a magnifying glass, at the center pin on the mustard colored connector. The pin is very small and easily bent. It will short out against the metal outer portion of the connector and result in no signal. It is 50/50 on whether the pin will break when attempting to straighten it. I learned all of this the hard way. ;)
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
What the current SW version of the radio after InfoT did their 'magic'?
Pink (Dedicated GPS) input isn't usually needed for GPS...( Think Hawaii with no SXM option)
Violet/purple is cellular (part of puck antenna)
Green/mustard is SXM (part of puck antenna & also functions for GPS)
Depending on your SW version (18.45.x is latest with GPS bug fix), you may have a bad puck antenna, bent connector pin as suggested, bad Sierra Wireless modem/gps card in the radio, or need the latest sw update
Rockshooter
Rockshooter
Tonganoxie KS
Very helpful.I have the latest soft ware update 18.45.Thinking I need to look at the antenna good info on the plugs.
Thanks Rich
SitKneelBend
St. Louis
3.6 Pentastar
Yes,you don't need the pink plugged in for the radio to function.
SitKneelBend
St. Louis
3.6 Pentastar
This, sorry got my wires crossed...
Rockshooter
Rockshooter
Tonganoxie KS
Just wanted to follow up with an update. Have my navigation working correctly now. If I would have listened to several senior members here I would have had it working three weeks ago. Stealership told me the radio was bad. Sent it to infotainment and had it
rebuilt and they installed the latest update 18.45 and returned it to me. I put it back in the truck. The navigation was still stuck in TX. So here's where I got to say thanks to several members on here. SHOULD HAVE LOOKED AT THE DAMNED SHARK FIN. After I replaced it, everything is working good.
Thanks Ram brothers!
Rich
joeyoliver45
