A_mod_too_far
I bought an open box set of the mopar plastic molded splash guards recently. The set didnt come with the hardware and I was wondering what goes in the hole on the bottom for the front set. Is it a bolt or a plastic push pin? Just not sure, they come with a little plastic piece that goes under there that I believe captures a bolt.
The back set are a little different and they just use the same fender well screw and u nut connection on the bottom.
This isnt a big deal or anything, I'd just be curious what it is. Thanks
