Bluetooth cuts out
SDSPANKS
Las Vegas
I just bought a 2022 Ram 1500 with the 8.4 display. I connect my phone to the truck with bluetooth to listen to music. The problem I have is that it just cuts off and goes to a FM station at random times. It doesn't do it with any other devices I connect my phone to. I've reset the radio and it still does it. Any ideas? Thx
tron67j
Maryland
If you are only having problem with the phone and other devices paired via Bluetooth don't replicate, then the problem is almost certainly in your phone. Try ensuing all software and app updates are installed on your phone (and radio), or try a hard reset (read about the process for your individual phone) if everything is up to date. You may have some glitchy software on your phone side. If that doesn't fix it, you could have a bad radio chip on your phone that sends something weird to your radio and not much you can do about that. Good luck.
VLG6963
