RamDiver
- Joined
- Jan 23, 2022
- Posts
- 2,124
- Reaction score
- 3,500
- Location
- Marlborough, Ontario, Canada
- Ram Year
- 2021
- Engine
- Hemi 5.7
The fault = the starter motor is receiving 12 volts at the solenoid wire
Trace the small wire from the starter (solenoid wire) either by color or physically following it back to the starter relay and determine why is has 12 volts constantly. This line should only have 12 volts when the key switch is in the start position.
The key switch start position should be triggering the start relay to close and supply 12 volts to the small wire (solenoid wire) on the starter.
