DIY: 2013-2016 (some 17-18) RearView Mirror Upgrade & Harness install
OnlyCesar
Mexico
Update: you dont need the 8.4 radio to enable auto-dimming rearview mirror and auto high beam lights just with alfaobd you can enable those features.
Tuggle
Simpsonville, SC
2019 Warlock & 2015 Big Horn
Looking to do this update. I currently have the 8.4 radio with dual ATC and humidity sensor. I have the manual mirror with Assist and SOS. I got a mirror with auto dim but not smartbeam. Mirror PN is 68342283AA the harness in my truck is 68374103AA
Would I need to get a new harness or would this be plug n play? If I need a new harness anyone know what the correct part number would be?
Thanks
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Thanks
Going on what year, model, trim of truck?
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Thanks
Mpgrimm2
This is going on a 2019 Ram 1500 Classic Warlock.
I got the mirror from a 2019 Ram 1500 Classic Big Horn.
I'm not terribly familiar with that harness (68374103AA with 10 pin connector & H sensor) on the 19+ classic vs 17-18...
There's a difference between the mirror connectors of a base manual dim non Sos mirror and upgraded 8.4 mirrors of a 10 pin connector vs 14 pin connector... And I don't recall which way or goes??
Can you tell which connector the new mirror uses? Here's the 19 classic DS 4th Gen connectors. (& I don't trust the descriptions)
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
@Tuggle
Fyi.... Looking at the verified 68207372AB harness for 13-16 trucks with upgraded mirrors, ... It has the 10 pin connector.
So I suspect your current harness should work with the new mirror.
Tuggle
Simpsonville, SC
You cant tell real good from the picture but the new mirror has a 10 pin connector.
I can pull my old mirror this weekend and see how many pins that connector has. Was hoping not to have to change the harness but if have to then have to.
Tuggle
Simpsonville, SC
@Tuggle
@Mpgrimm2
Thanks for the info. I will try and swap the mirrors this weekend and let you know if it works.
Tuggle
Simpsonville, SC
@Tuggle
@Mpgrimm2
Harness had the same connector as new mirror. Got it installed and setup with AlfaOBD, now have the icon on radio. Seems to be working, will take it out for a drive tonight to see if it dims.
elexwiz
Virginia
Adding my experience here, as suggested by @Mpgrimm2, for enabling the auto dimming rear view mirror, the auto dimming high beams, and the Automatic Temperature Control (ATC).
@Mpgrimm2 helped me through the radio, climate control, and rear view mirror upgrades. I have a 2015 1500 Tradesman. It had the basic analog radio, basic rear view mirror, and the standard climate controls. I found a 911 mirror with the mics on eBay, bought the radio and ATC components through M2 Mods, and bought the factory wiring harness for the 911 mirror (p/n 68207371AD) through MoparPartsGiant.com. The factory harness has a connector for the humidity sensor.
After installing all the components, I activated the mirror, auto dimming high beam, and the Automatic Temperature Control using the following steps.
Auto Dimming High Beams
- Body Computer
-- My2015 PowerNet (choose your applicable PowerNet)
--- Car Configuration Change
---- VehConfig 1: Auto Highbeam = Yes
---- VehConfig 3: Auto Headlamp Feature Present = Yes
---- Cust.Set.Menu 1: Auto High Beam CSM Present = Yes
---- LIN and Misc: Smart Beam Present (AHBM) = Yes
---- 2014 CBC Config I/O & Feat.: Auto High Beam Module Location = ECC_AHBM
Auto Dimming Rear View Mirror
- Body Computer
---- VehConfig3: Interior EC Mirror Present = Yes
Auto Temperature Control to Single Zone ATC (requires dual zone config first. Your initial setting should be "Single Zone MTC")
- Body Computer
---- VehConfig 3: HVAC Configuration = Dual Zone ATC
PULL RADIO FUSE NEAR BRAKE BOOSTER FOR 30 MINUTES
REPLACE FUSE AND VERIFY DUAL TEMP SLIDERS WITH DEGREES IS DISPLAYED BEFORE PROCEEDING
---- VehConfig 3: HVAC Configuration = Single Zone ATC
REPLACE FUSE. UPDATE SUCCESSFUL WHEN SINGLE TEMP SLIDERS WITH DEGREES IS DISPLAYED
