My front windows are not working
SugaryClapz
WI
Couple days ago I hopped in my truck and tried to roll my front windows down and they are not working all of a sudden. My mirror adjuster and locks won’t work either, but rear windows roll down. Any help would be appreciated!
Dean2
Near Edmonton
Will the passenger window go up and down using the passenger control. Will the doors lock using the passenger side switch and will they lock and unlock with the remote. A little minor diagnostic work can save you a lot of time. It also quickly helps narrow down the number of things that can be the cause.
gofishn
Iowa
hemi 5.7L, 345 cu in
Pull switch. get schematic for which wires for which window and jump terminals to insure it is the switch but
..... sounds like it is the problem
pretty Common
had mien replaced 3 times udner warranty on my 2014.
SugaryClapz
SugaryClapz
WI
pretty Common
Got a new switch coming!
SugaryClapz
SugaryClapz
WI
All the other switches work accept for the driver side. I got new switch coming!
SueH
Fort St James BC
Im having similar issues with the drivers side switch ...I replaced it ...was good for couple days ...Now it will only roll back windows down ...New issue today not this type but my darn ac is blowing hot air ... feeling a bit tantrumish.
heavyhands
Canada
5.7L
I have the same problem, i changed the switch and driver door module. Still doesnt work!
Mike Townsend
I've ordered two or three switched off of Amazon or Ebay and none work like they should. First they all come with amber backlight for some reason. Secondly it will only roll down one window at a time which is dumb. I tried to order one from Steve White and it was cancelled because it was on national backorder.
dikbeard
Canada
Hey, i just went through this with my mechanic. After 2 months of Diag, a new OEM door switch, a new OEM Door Module and a BCM flash seems to have worked.
Long story short, we did 3 door switcheswhich that didnt solve the problem, then a new Door Module. The door module was giving us a "mismacth ID" but thats becasue the Window switch was NOT a Mopar OEM part. We did both new door and window modules at the same time with a flash, now it all works again! hope this solves your issue, it was such a pain to figure out.
Treburkulosis
Your High End Detailer
Haslet, TX
Well I hope my amazon passenger side switch works... Its coming today.
Treburkulosis
Haslet, TX
Well my amazon switch came yesterday and although it feels cheap it works so I will take that.
Treburkulosis
Haslet, TX
I just ordered from the same place for my passenger rear. The boys broke the plastic holding it up. It should be here Saturday.
Freakydude
ontario canada
Ecodiesel
check the fuse, you could have blown that. If fuse ok then get an electrical DC current meter, start at the switch to see if you have power and trace it backwards
Digi
central us
How would you know which door module is bad? I can roll every window down except front passenger. Also can't adjust the passenger side mirror. The passenger side switch doesn't work for anything. So would that mean driver side or passenger side module bad? New master switch works for everything else, so know that's not the issue.
