Reel Hard
Has anyone converted their turn signals in their mirrors to running lights and still have them flash when using turn signals? I have a 2017 Laramie without the tow mirrors.
These are plug n play ones that I build for this vendor- https://dudesdieselperformance.com/...r-light-harness-13-18-ram-1500-2500-3500.htmlHas anyone converted their turn signals in their mirrors to running lights and still have them flash when using turn signals? I have a 2017 Laramie without the tow mirrors.
First I've seen this. Looks a lot easier than the others I've foundThese are plug n play ones that I build for this vendor- https://dudesdieselperformance.com/...r-light-harness-13-18-ram-1500-2500-3500.html
Unlike the ones posted above, no pulling wire through the doors, and no splicing/cutting/tapping wires. They just plug online to the door modules.
Yes, they work on all ram mirrors with turn signals (2013-2018, 2019+ classic).Do these work on full power Laramie longhorn nontow mirrors?
I have the same question. I don’t have tow mirrors.Do these work on full power Laramie longhorn nontow mirrors?
Here’s a walkthrough of someone installing them. Also several different members pics of them lit up. All tow mirrors, but same thing with the non tow mirrors. https://www.cumminsforum.com/threads/tow-mirror-running-light-mod-the-easy-way.2525419/Next question would be does anyone have any pictures of the lights at night that has done this mod?
No, AlfaOBD can’t do it.could this be programmed with alpha obd?
Pm sent.Can’t find these on the DDP site. Keep getting an error 404. Anyone know if they’re still making these?
I see it just uses relays to make it blink, I am assuming it blinks out of sync with the other turn signals? Like when the headlight and taillights turn signals are on these are off and vice versa. Or does it blink in sync with everything?I used this kit - it was an easy install. Did have an issue with one of the solenoids not working but the seller was prompt and sent out a replacement asap. Everything works great.
They have a new website. Here's the current link to the kit.
DDP Motorsports | 2013-2018 Dodge Ram 1500 / 2500 / 3500 Tow Mirror Li
****Please keep checking back here or subscribe to our newsletter to stay up to date on when this harness will be available. Test harness is currently in our test truck and the new GEN 2 harness will be available soon!**** Plug N Play Mirror Running Light Harness for 2013-2018 DODGE...ddpmotorsports.com
