I have NOT pulled with my Ram as of yet. It was bought to replace my rusty Dakota with I did pull with. But what I pulled was our 66 Satellite on a 16ft steel deck car trailer (6000 lb for those two together). The Ram will see no more winters and the Dakota saw all of them during the 22 years I owned it. It was two wheel drive,4.7, 5 speed manual, 3.55's Got 15mpg from Albany NY to Canton NY going through the Adirondack Mts. Not only was it a stick (where I could choose the gear "I" wanted when "I" wanted it, but the roof of the car on the trailer was no higher than the cab of the truck. I got my Ram (16, 1500, Reg Cab, 6sp auto,3.55's, 5.7) to pull what I have. What ever it gets is what it gets (hoping to get the same 13-15, but from what is said here- doesn't look good). Anyway here is something learned: speed does not always get you there faster! depending on the distance your total time will be close to the same. 675-700 miles @ 65 mph and 9mpg+ 3 stops to fill and go. vs same distance @ 58 mph with maybe 13 mpg would be longer drive time but 1 less stop. Not only that but it will be easier on the vehicle. ??? All I know is because of all those out there that want "automatics" I could not get (because no one could order a 5.7 with a speed manual!!
