- Joined
- Nov 19, 2020
- Posts
- 1,003
- Reaction score
- 1,174
- Location
- Saskatoon SK. Canada
- Ram Year
- 2021
- Engine
- 5.7
Non electronic guy here..appologies..wondering if I can put aftermarket light bars where the OEM footwell light is and tap into that power circuit without issues? Can same be done with the Dome light? 2021 Ram Quad Cab Classic..Warlock..
What method do I tap into that power wire for the OEM bulb ...I would take out that bulb as it would not be required ...or do I have to run a wire from the new light bar to the fuse box and do an ATO (ATC) fuse expandable circuit power adapter ( 5 amp )..I think that is what it is called..thanks
