JJP71584
What bolts should I check if I'm trying to correct an exhaust leak also known as the Hemi tick? I have a loud ticking on passenger side when engine is cold, stealership wants to charge over $100, just for diagnostic, and I'm out that if it's not considered to be covered under powertrain warranty...thanks!
" Then any sound that sounds like its coming from the engine would be covered under warranty as far as diagnostics.. cause then it turns into "Oh yeah its just an exhaust leak, its going to cost 1.75 million to fix it" instead of them charging you to tell you that
