3 way coolant valve
  1. Oxygen454
    P26AB – Engine Coolant Bypass Valve Diagnosis
    2013 Ram 1500 3.6L Fault Code: P26AB – Engine Coolant Bypass Valve / 3‑Way Heater Coolant Valve Stuck or Malfunctioning Summary of Symptoms The fault began as an intermittent issue. Clearing the code would temporarily resolve it, but the CEL returned within a few days. Eventually the code...
  2. D
    2014 1500 v3.6 voltage issues
    new to the group and new to being a dodge owner - so please be easy with me getting various dtc's p0123 throttle / pedal position sensor circuit high p0222 throttle / pedal position sensor circuitt low p2683 engine coolant bypass valve - circuit high p26A6 engine coolant bypass valve - circuit...
tburger
